Travisl New Member Mar 21, 2008 #1 my crx wont start i sprayed starting fluid in the throtle it started then died
LS_VTEC you get the BRAKE Mar 22, 2008 #3 No fuel in the tank, bad sending unit, bad pump, bad injectors and so on. Have a shop check the fuel system.
Justin66 The Hondaswap Canadian May 22, 2008 #5 Sounds fuel if it starts and runs with fuel sprayed in it. Is the fuel pump coming on? (should be able to hear it when you turn on the ignition)
Travisl New Member Jul 7, 2008 #7 my crx is not running again i changed dizzy internals but its not getting a spark
