CRX wont start
Discussion in 'Civic and CRX - EF' started by 34diesel34, Apr 28, 2013.
  1. 34diesel34
    34diesel34 Import Tuner
    USA
    My 91 CRX wont start. All I get when I turn the key is a buzzing sound, and I can hear the fuel pump turn on. I pulled the starter and battery off and had them both tested and both tested good. I have tried another ignition switch, main relay, starter relay, and clutch switch. The car still will not start. :mad::mad::mad:
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    is the ecu dead. check and see if it has a light flashing.
  3. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
  4. 34diesel34
    USA
    The check engine light comes on when I turn the key and then it goes out. It's solid while it's on, and not flashing any trouble codes.
  5. 34diesel34
    USA
    :confused::confused::confused: WTF. The car radomly started. No parts have been changed, and no loose grounds or bad connections were found. The only thing I did was disconnect the #1 spark plug wire to check for spark and the car tried to start when I turned the key. I reconnected it and the car started up. I haven't been able to get the car to turn over for three days. I have no answer for why it wouldn't start for the past three days????
  6. Briansol
    maybe that wire was lose? does it re-start now?
  7. dilbeckskate
    Kennesaw Ga
    idk ef's have a mind of their own, main relays, fuel injector resistor packs all sorts of stuff on those cars can decide one day they arent going too work till you just talk too her the right way
  8. Briansol
    ignitor's are common problems too.
  9. 34diesel34
    USA
    Yes it starts now but that wire was not loose. I took it loose to check for spark, and the car turned over when I turned the key. Then I reconnected it and the car started up. I didn't change any parts on the car, didn't find any loose wires or bad connections or bad grounds. It started up out of the blue. I had to spend $80 to have it towed home.
  10. dilbeckskate
    Kennesaw Ga
    well quit whining and enjoy it, it runs now
