I just replaced the timing belt, spark plugs, gas, plug wires and I still have nothing...? What should I try to do next. I want this thing to crank.
yeah does it crank when you turn the ignition? if it does then double check your fuel and spark. if you have that, double check your timing. if it doesnt crank over then check your ground lines to the starter and the other ground lines to the battery ground. good luck!
