CTR cams in LS/VTEC motor
eghatchvtec
I have heard that you CANNOT run CTR cams in a LS/VTEC motor with stock LS pistons, because piston to valve contact. True or False? Any info would help.
my motor:
94 LS block (stock w/ LS pistons)
00 B16A head (stock)
CTR cams - will it work?
head has not been milled.
i did it before and it ran ok......you cant adjust the cam timing with the adjustable cam gear (not much room for clearance).
