ctr/itr steering wheels
Canadian_GSR
K im curious if anyone knows the diff between the ctr and itr wheels (jdm). I got one pretty cheap at the junk yard, with airbag. thoughts.....
Some times they are the same, although some came with airbags and some did not, even in years as new a 96-00. I think a supplemental restraint was an option in Japan. Wish you could do that here
thanks smartass, i mean if the splines are different where they mount up n shit, and if the wiring harness for the srs will plug into my eg. thanks
The hubs are different size's. The ITR's will fit a civic, but the CTR's is too big to fit the civic hub (funny huh?)
Damn, If I was home I could measure the inside of a civic steering wheel I have sitting around, but I'm not and won't be for a couple weeks. Run to a junkyard and pull one off a civic and measure the diameter and then compare it to yours.
