CTR or ITR pistons?
Discussion in 'General Tech and Maintenance' started by NightCat, Sep 23, 2007.
  1. NightCat
    NightCat New Member
    Well, the title basically states my dilemma.
    I'm going to be building up a B18A1 and I'm debating over which pistons I should go for.
    any suggestions or information that would lead to one or the other?
  2. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    Is it a straight B18A1 or an LS/Vtec? What are you building the engine for? For boost or N/A? I think this is why no one has answered you and you posted this on the 23rd.
    Go here: Honda, Acura Tech Website, tutorials, tuning and HOW-TO's. Drag racing, street racing, road racing - C-speedracing.com
    Plug in your information and figure out your compression ratio, and you can kinda go off of that. Of course CTR pistons have a higher dome than the ITR, so you can expect a higher CR.
    B18A1 w/ stock pistons: 9.2:1 CR
    B18A1 w/ CTR pistons: 11.4:1 CR
    B18A1 w/ USDM ITR pistons: 10.3:1 CR
    B18A1 w/ JDM ITR pistons: 10.8:1 CR
  3. NightCat
    NightCat New Member
    Well, here's some background information then,
    I have a 1991 Integra with factory B18A1.
    I dont like how slow it is now, however I dont wanna sacrafice fuel economy for power.
    It's my daily driver but I want it to be a bit more fun. I'm aiming for 300whp and still be daily drivable
    I'm most likely gonna go LS/VTEC and boost, probably no more than 8 psi.
    I was just lookin around hmotorsonline and I happened to see CTR and ITR pistons, complete sets for $169 and I thought that was a damn good deal.
    I know that boost and higher compression pistons isn't that great of an idea and you really want lower or stock compression on boost.
    sorry I didn't include information
    This is my 2nd engine build, first build was a D16Y8 + boost
  4. scottp11
    You can have a higher compression ratio with boost, but there is less room for error with your tune. I mean, your tune has to be on point...
    If you're only planning on running 8 psi, you should be fine with your stock pistons and have a CR of 9.2:1. I don't know your money situation, but you should at least use a block guard, if you don't have the block sleeved.
    The Vtec head you use will also play a factor in your compression ratio due to combustion chamber volume.
    B18A1 w/ stock pistons and stock head: 9.2:1 CR
    B18A1 w/ stock pistons and B16A head: 9.5:1 CR
    B18A1 w/ stock pistons and B17A head: 9.5:1 CR
    B18A1 w/ stock pistons and B18C head: 9.7:1 CR
    Also using a thicker head gasket will lower your CR a couple points also.
  5. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Around 10:1CR is fine for boost. Highest I've seen is 11.5:1 in a some 300-400whp GSR. You can get away with moderate compression as long as you get a very good tune.
  6. scottp11
    That's what I said.... I have a stock JDM B16A with 10.4:1 CR w/ a turbo and Hondata S200.... Making 280 whp.
