hey whats up. I was just wondering if you can use the oversized CTR pistons (81.25) in a LS block? Cause the bore of the block is 81 (which im sure all of you are aware) i was just wondering if u can still use this pistons, cause i was thinking that there was be some clearance from the piston rings. thanks, can use your help.
