CTR
Discussion in 'HYBRID -> EG-EK / DC' started by DaNn25, Jan 25, 2004.
  1. DaNn25
    DaNn25 Junior Member
    i need more torque on my CTR stock ....what is the best part for this ????
  2. dohch22a4
    dohch22a4 Senior Member
    Spokane, WA
    A B18 or B20 block. Sorry, dude. The B16 is called the torqueless wonder for a reason. Too bad you probably spent too much on your CTR swap.
  3. illmatik
    illmatik Senior Member
    New Jersey
    b20 dat bad boooyyyy
  4. civicext
    civicext Member
    usa
    well if you have a ctr motor well look at spoons stroker kit they use a ls crank for there kit that will give you an ideal... but if i am wrong some hit me up about it :ph34r:
  5. B16
    B16 Super Moderator VIP
    yay area, CA
    if you want to add stroke just thro a gsr crank and rods in that b16b block, its the same block as the gsr/itr. this will get you the biggest torque increase. or you could change out the pistons for higher CR (not too large of gains). or get bigger cams (better results if you do both pistons and cams). depends on your budget really.
  6. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    increase displacement
  7. pissedoffsol
    sell it, buy a b16 that makes the same damn power with its cams, and have 3k left over to boost it =)
    but seriosuly, b20 block is a good idea
  8. dohch22a4
    Spokane, WA
    :werd:
  9. Slammed90Lude
    Slammed90Lude Senior Member
    milford, PA
    yeah dude buy a crv block and throw your TYpe R head on it- woo hoo CR-VTEC
