Custom Wastegate Dump And Trim
Discussion in 'Forced Induction' started by colorpros, Apr 8, 2003.
  1. colorpros
    colorpros Senior Member
    I shot the dump right out the side of the bumper.Then went to lowes and bought some stainless steel and made that rtrim piece and rivited it to the bumper.
  2. GSRCRXsi
    MD
    thats awesome man, but can you axplain to me exactly how that works if you have it hooked up to your exhaust?
  3. colorpros
    It comes of the wategate.There is a flange on the wastegate and its welded to it and routed outside the bumper.When boost levels exceed your spring pressure or your boost controller setting the excess boost comes out that pipe w the sound of freaking ripping metal.I guess that should sum it up in a geeky kind of way...
  4. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    you riveted stainless steel to plasitc? how?
    and obviously for less resistance, but why else have the dump instead of just send it out the exaust?
  5. GSRCRXsi
    MD
    so most of your exhaust is still going out the system like normal? does what you have setup add any extra power when it engages?
    cause i thought you had your exhaust setup so that you caould choose for it to dump out of the side when racing or go throught exhaust while driving normal. still awesome either way
  6. SixtySecondAssassin
    Austin, TX
  7. liquid00meth
    Laconia, NH
    uhh yes actually I do know what a rivet is, and I ask because i would usually assume a rivet could spider plastic
  8. SixtySecondAssassin
    Austin, TX
    there are different types of rivets. im sure he didnt use the kind that hold planes together that you have to use an air hammer to install. rivets were designed for applications like these
  9. liquid00meth
    Laconia, NH
    well alright then chief, no need to ask me if I know what a rivet is, like an idiot . I just don't happen to rivet things together alot, sue me
  10. NoJokE
    NoJokE Senior Member
    Wouldn't it have been better(safety wise) to put it behind the tire? Just asking, cuz i saw somewhere it could spit sparks out of there sometimes
  11. SixtySecondAssassin
    Austin, TX
  12. machine
    machine Banned
    houston tx
    i saw a setup like this on an Integra, but he had the wastegate fed in to a motorcycle/dirtbike? muffler, so it was quiet i guess, but not very stealthy with a hole on the side of the bumper. Either way i'm down with DIY and that looks really cool. Any performance gains noticed?
  13. colorpros
    I dont know about a performance gain.The rivets I used where small..Im not to worried adout where its located being that over 80 percent of cars in the NIRA are the same way.
  14. liquid00meth
    Laconia, NH
    regardless of what rivets and where it is, I think it looks fuckin' badass. :thumbsup:
  15. colorpros
    thanks hommie...
  16. machine
    machine Banned
    houston tx
    not to bogart your thread, but someone on here told me you know about painting carbon fiber. Is it true?
  17. colorpros
  18. BigJ
    Damn I want turbo now. :D :D
  19. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    Just playing devil's advocate here...
    How do you deal with the flex of the motor mounts? Do you have a flex joint in the tubing at all to allow for the moving of the engine?
  20. colorpros
    there is about a 1/4 inch of space all the way around the pipe.So far I havent had any trouble
