cutting dead coils
Underage
Member
is it possible to cut a dead coil or two off of the stock spring in a 91 civic? i want a 3/4 - 1 inch drop but i don't want to ruin spring rates.
well if its shot anyways its not going to make a difference, dont cut em . if bottoming out and shitty handling is your thing then good luck.
Cutting coils will actually increase your spring rate and make it even more bouncy. Don't do it. Leave it as is and save up some cash for another set of springs.
heat them up with a torch and have all your friends sit on top of your car
:ph34r:
i thought if you cut dead coils that it doesn't do anything to your spring rate. i was just wondering if civic springs have a dead coil that i could cut off.
by dead coil i mean a coil that sits right next to another coil and doesn't compress.
