cylinder head replace
to replace the cylinder head will i need to remove the engine from the car or can i just a easly do it with out removing the engine?
thanks
You do not have to pull the engine.
One major suggestion to you is to pick up a helms manual. They have basicly step by step how to's. Also, if your pulling the head, your going to need to know all the diffrent trq. specs for everything. It is not something that you can just guesstimate.
