Cylinder Not Firing
Discussion in 'General Tech and Maintenance' started by Jay SWAT, Feb 20, 2009.
  1. Jay SWAT
    Jay SWAT New Member
    94 LS high compression n/a motor
    I have fuel pressure, i have spark, swapped distributors and still i have one cylinder not firing.
    Any ideas?
  2. MthaFuknGreen
    Lodi, CA
    how do you know its not firing?
  3. Jay SWAT
    Jay SWAT New Member
    You can feel on the valve cover.
    Its running jacked up.
    And 2 mechanics have said the same thing.
  4. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
  5. Jay SWAT
    Jay SWAT New Member
    No compression in that cylinder?
    What can i do for that?
  6. AHHVTEC
    Alabama
    yeah check the cylinder for compression thats giving you problems. if it it has none then it 1 of about 4 things
  7. Jay SWAT
    Jay SWAT New Member
    Could you list them off for me please?
  8. AHHVTEC
    Alabama
    bad rings,hole in the piston, valves,or head gasket
  9. Jay SWAT
    Jay SWAT New Member
    I just got the motor back from being completely rebuilt so i'm hoping that is none of these things.
  10. AHHVTEC
    Alabama
    well your injector on that cylinder could also not be firing
  11. monty92
    monty92 New Member
    regina, sask
    do a compression test and if one cylinder has no compression try putting a little oil then retesting that will tell u if its rings or not
  12. Jay SWAT
    Jay SWAT New Member
    Compression test checks out good
  13. Jay SWAT
    Jay SWAT New Member
    Also swapped injectors and connectors around and still the same cylinder wont fire.
  14. AHHVTEC
    Alabama
  15. Ethan
    Ethan Well-Known Member
    Just had the same issue. mine was head gasket.
    head gasket and two stripped out spark plug holes. i hate the mexican that owned it before me.....
  16. George777
    George777 ^^ Likes Bewbies
    With your mom
    Bad wire, too. Bad contact on cap. Cylinder gremlins clogging it up.
  17. MthaFuknGreen
    Lodi, CA
    tell injen to get outta there.
  18. 94H_Ex
    94H_Ex Under employed
    Florida
    put a grenade in the engine bay, shut the hood and run away. then you wont have to worry about it any longer.
  19. MthaFuknGreen
    Lodi, CA
    wheres he gonna get a grenade?
  20. phyregod
    phyregod !!YTINASNI
    Central Texas
    Army surplus store. Fill that fucker with gun powder, slap in a fuse, and you're back in business.
