neomodus
Ok get ready for a spill...
I have a 94 Civic Ex, D16Y7 Block, D16Z6 Head, new distributor.
Engine cranks fine, but the first cylinder does not fire. The throttle is inconsistent as in it pulsates so to speak. It will never settle as if it is struglling to stay alive. I have checked the compression which is fine. I checked the distributor with a screw driver and there is spark. The inside of the cylinder is sparkling from the gasoline cleansing it receives. I have checked the timing numerous times.
Any clues?
Should I adjust the valves, get new injectors, get a whole new intake manifold?
I really wish this would work its been a huge pain.
Any clues?
