D 15 B rebuild, need help with the timing
Discussion in 'Civic and del Sol - EG and EK' started by knuckledog, Jun 14, 2008.
  1. knuckledog
    knuckledog New Member
    Ocala ,Florida
    i just rebuilt my D15 b7 ( all stock ), i just need reliablity, anyways i finished the enging yesterday and went to fire it up , but it is hard to start, and it stalls out at idle, when i installed the cam , the cam gear looked like it was 1 tooth off, but i thought i could adjust the distributor ( like a chevy) and correct it , but as you all know the distributor is limited on how far it will turn , if i turn it foreward it will not start, but if i back it up all the way , it fires , but stalls out, :confused:
    any help or advise would be appreciated alot, thanks i am new to the site and honda's:)
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Fix the cam timing issue. Adjusting the distributor will only change the ignition timing, but won't do anything for the cam timing.
  3. knuckledog
    Ocala ,Florida
    okay that is my plan of attack then, i will just give yall a lil info on the issue that started it all, It started with a burnt exhaust valve, so i took it to a " mechanic" or at least he claims to be, anyways i told him to just replace the valve ONLY, but he rebuil;t the entire head( well he had a machine shop do it) but he pulled it and installed the head, asoon as he fired it up it was smokin like cheech and chong!, so bad you could not even see behind you, then he says" I dunno what to do now??", i told him he was a jackoff, and that he blew the piston rings out, so i took it home , bought a repair manual for it and rebuilt it myself, i followed all the steps and instructions carefully, ( i used to rebuild small block chevys,fords, and dodges), so iam very mechanical, but never a honda. , i l;ove my honda, it is a good car, and i have got good use out of it, and i will never sell it,
    so if you all have any other hints or tips , please let me know,
    thanks much!
  4. knuckledog
    Ocala ,Florida
    does this sound weird to you? i have not messed with the cam timing yet , but it will run while cold engine, but when it warms up it stalls? is that cam timing too?, seems weird, but i will adjust the cam today,, can you comment on this issue?
  5. knuckledog
    Ocala ,Florida
    i build hi pro v8's new to rice burners, and no i am no shy to say i am a noob to honda's,
    i used to eat up honda's in my 67 chevelle ss, but now thar gas is so expensive , i choose to drive honda,,, ask me any hi pro v8 question.....try me
  6. knuckledog
    Ocala ,Florida
    seriously i have no chip on my shoulder, i just asked a question to see if it was common in honda's... thats all... in a chevy you can be 2-6 degrees off on your cam timing, and just move the plug wires around on the cap and change the posistion of you #1 wire.... just wanted to know if honda was the same, and how touchy the cam timing was....and i have a manual......
    but lets get somethin straight, i have no chip on my shoulder, but i dont like smartass comments....thats all ....,, i am a really cool guy... just here to make friends and learn about hondas
  7. knuckledog
    Ocala ,Florida
    its cool man..... no worries...;)...., anyways,, so what kinda car you ride? obviously honda,, but what motor and mods?
  8. knuckledog
    Ocala ,Florida
    hey i like your civic build, i looked at your thread, i like the cam, and the way you put it all together, have you boosted it yet?
  9. efhondakid
    Akron-Canton, Ohio
    I think he abandoned that project.
    Oh and some V8 trivia for you, The big Buicks are known for oil starvation on what component(s)?
  10. knuckledog
    Ocala ,Florida
    rod bearings, and lifters ....thats why guys add oil lines up top and drill out the block, and a hi volume oil pump is a MUST
  11. knuckledog
    Ocala ,Florida
    trivia for you what is the leading cause of oil pressure loss in those engines, and what do the olds 350 and 455 have in common?
  12. efhondakid
    Akron-Canton, Ohio
    Shitty oil pump on the Buicks, same motor the 442 was just the higher end model, 4-four barrel carb, 4-four speed manual tranny, 2-dual exhaust.
  13. knuckledog
    Ocala ,Florida
    but that still does not answer my question ,, what do the olds 350 and 455 have in common?
    as for the 442 your right , but it was a 2 door too...
  14. knuckledog
    Ocala ,Florida
    hey queston for you,, how touchy is the cam timing in the d-15 b7?
  15. knuckledog
    Ocala ,Florida
    wow 9 degrees!, olyy sheet mon! dude you just solved my timing issue, i knew i was off by 1 tooth,, i tried to half ass it with the cam gear, by lifting up the cam and slipping the belt on then bolting down the valve train,, ((cheating!!!)) , I AM SO USED TO CHEVY V8'S that is why i thought i could cheat,, but now i know why my car runs so rough,, does the crank pulley require a jaw puller to get it off? or a damper puller?, or just a screwdriver?,, i had all of the tools i ever needed in oregon, but i moved to florida, and left them behind at my X's house,, so i need to know which puller to buy?,,, harbor freight here i come!!!,, lol..
    blanco thanks alot for your help
  16. dacheat
    dacheat ..is grounded.
    strongbadia
    i :wub: this thread, voting it high and 'scribing for future nerd knowledge :D
  17. knuckledog
    Ocala ,Florida
    lol
