D series interchange tranny
Discussion in 'Civic and CRX - EW' started by TegNation, Oct 19, 2007.
  1. TegNation
    TegNation Honda Luv!
    Va
    ok i just got a 88 d16 hatch, love the car but the tranny just went, i own a wrecked 90 d15 rex, will the tranny out the rex fit my hatch??? Thanks Dan.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    yes it will bolt right up
  3. TegNation
    Va
    even tho one is 1.6 and one is 1.5???
  4. AHHVTEC
    Alabama
    yup it dont mater any d series tranny will work
  5. TegNation
    Va
  6. AHHVTEC
    Alabama
    no problem, dont forget to rep me :D
  7. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    Get an ex or si tranny and rep ME for that one :D. LOL
  8. AHHVTEC
    Alabama
    better yet get a year 2000 ex tranny and convert to hydro + rep me double for that one:D:D
  9. jlicrx
    jlicrx Senior Member
    Colorado Springs
    if your 88 still has the 88 transmission, you will need to change the clutch in order to use the 90 transmission - different splines on the input shaft between 88 and 90
  10. TegNation
    Va
    ok so one person says its direct fit, yet another says spline change? if true. how hard is it to change the input shafts?
  11. jlicrx
    Colorado Springs
    you don't need to change input shafts (not an easy job) - just get a clutch disc for 89 Si or swap the flywheel, pressure plate and clutch disc from your 90 onto the 88 - 90 uses a larger diameter clutch than the 88-89
  12. AHHVTEC
    Alabama
    dude it is a direct bolt one you have evey thing you need, just what ever tranny you use also use the fly wheel and clutch for it
  13. TegNation
    Va
    so if i put the 1.5 tranny in use 1.6 clutch??
  14. AHHVTEC
    Alabama
    use the d15 tranyy cluch and fly wheel on your 1.6 motor
  15. TegNation
    Va
    awesome the d15 got a fresh clutch like 50 miles on it when it wrecked!! ok in like 3 days we will see who is right. i sure hope u are ahhvtec!!!
  16. dacheat
    dacheat ..is grounded.
    strongbadia
    :popcorn: i wanna know, so come back and tell us ok! i have a similar sitch brewing..
  17. TegNation
    Va
