D series ITB?
Discussion in 'Engine Building' started by CRX2NR18, Apr 8, 2004.
  1. CRX2NR18
    CRX2NR18 Senior Member
    i cant find an ITB D series manifold? i seen a guy on homemadeturbo.com made one for a B series, would it even be worth it on minime? jw
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    I have seen it on a d-series, but you will have to make them yourself most likely.
    On honda-tech in the allmotor forum, there is a 6 page thread on people showing off their ITB's. There was one or 2 d-series in there.
  3. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    I've seen some people make them from motorcycle ITB's using a D series IM flange. Once I saw someone sellling these also, on Honda -Tech too I think.
  4. CRX2NR18
    will it even give me any HP? what are the benefits of getting one? and what would i have to do extra because i know i would have to get an upgraded fuel system
  5. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    Unless your running high compression and huge cams your not going to see any results with ITB's.
  6. pissedoffsol
    First, let me say that i think you're wasting your time and money. It will cost about the same as a b16 swap to put itb;s on your d-series, and the stock b16 wil still smoke your itb'd z6
    that said,
    CBR 929 ITB's are a STUPID close match. 2 and 3 are just slightly off. you can get a set of those for about 500-1000 on ebay.
    next, you need a stand alone
    next, you need to figure out how to idel your car
    next you need to figure out how to hook up everything that runs off vacuum- aka 90% of your cars accesories, fuel, and emissions stuff
    now, you build a D-series head that can actually USE Itb's- hold revs to 12k... aka- never going to happen in a d-series. 9 is pushing it. cam overlaps are just too restrained on the single cam...
    itbs will start being being effective around 5k, and won't make any real power gain until 7k
    so, now, do you still want to do this?
  7. NetLogic
    NetLogic Junior Member
  8. D See 2
    D See 2 Senior Member
    Baltimore, MD
    those guys on HMT have some nice write ups. thats a decent one right there.
  9. typeRlos
    typeRlos New Member
    Now i have a question what about if i dump about a 50 shot through each itb? Whould that help in the sigle cam set up?
  10. efhondakid
    Akron-Canton, Ohio
    Stop thread-jacking. And a 50 shot in each one is a way bad idea, youll melt a piston real quick.
