D-Series Oil Pump
Discussion in 'Engine Building' started by GlassHeadlights, Jul 5, 2009.
  1. GlassHeadlights
    Calgary, AB
    I'm rebuilding a D16A6 block. It has really high miles (almost 300,000).
    I'm going to replace the oil pump but just for giggles I took apart the pump that came off of that motor and I also took apart a oil pump that came off of a D15B2. The D16A6 one showed normal wear, it should be replaced but the D15B2 one was MINT underneath.
    Could I use the D15B2 pump on my A6 block? I'll post pictures up if wanted.
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the D16A6 and D15B2 engines use the same oil pump
  3. GlassHeadlights
    Calgary, AB
    Thanks but I took another look at everything and I don't they are the same.
    I'll just buy a new pump.
