D series swap into my 86 CRX SI
Discussion in 'HYBRID -> ED-EF / DA' started by xips(86CRXSI), Aug 12, 2005.
  1. xips(86CRXSI)
    xips(86CRXSI) New Member
    Portland, OR
    Will I need to change the computer to run a D15 non-vtec in my 86 CRX SI?
  2. Celerity
    Celerity Well-Known Member
    You have a D15 non-vtec :)
    I asked in the other thread, but I'll continue this here. I'll assume you're putting like a 1991 Si motor in it. Your ECU will handle it, but the connectors are all different. To be in for the good haul, you should bring over the donor ECU as well. Also, the wiring is run through a significantly different path.
    I have both the 87 CRX D15 (EW4) and the 91 Civic D15b3 if you need any side-by-side comparisons.
    But we can get you into a more worth-while swap. For both performance and economy.
  3. xips(86CRXSI)
    Portland, OR
    so can you send a pic of the two engines whare the timeing belt mount is from the front view would be nice. thanks
