d series water pump differences
Discussion in 'Civic and CRX - EF' started by ibdalovely1, Mar 11, 2009.
  1. ibdalovely1
    ibdalovely1 New Member
    dayton ohio
    d series water pump differences is there any
    ive got a a6 block and a z6 head
    and what timing belt to use with it
    i did a search all i got was a bunch of expired ebay stuff
  2. sevenhillsbilly
    sevenhillsbilly New Member
    im pretty sure you use the z6 timing belt because thats what i did and i have the same mini me swap
  3. ibdalovely1
    dayton ohio
    i was gonna change the water pump while it was out but is one better then the other a6/z6/y8 or should i use just a a6 pump to make it easy
  4. sevenhillsbilly
    use the A6 pump to make it simple
    1 person likes this.
  5. Z6CRX
    Z6CRX übber ɐɾuıu etarip
    Pittsburgh, PA
    rep+
    use the same bottom end components. I think the number of teeth are different though. i did a mini me, keep the bottom ends water pump, i forget the belt off hand but search in our FAQ section here.
  6. sevenhillsbilly
    im pretty sure you use the belt for the head so you dont mess with the timing.
  7. Z6CRX
    Pittsburgh, PA
    yeah but if i remember correctly you'll still be off by a like half a tooth or something. most people just get an adjustable cam gear to fix that though, or just run it how it is.
  8. sevenhillsbilly
    yeah i noticed that with mine its not quite exact but for the break in im leavin it how it is but once its runnin good im gettin the adj cam gear.
  9. Brujo13
    Brujo13 New Member
    i thought that it was better to use the water pump that matches the head so that the belt would ride it properly, asfar as i know they are the same except for the sprocket and the correct belt for the head
  10. ibdalovely1
    dayton ohio
    is there some one that can tell me witch to use im ordering parts soon and i need to know please is there a sticky on this somewhere thanks all
  11. Z6CRX
    Pittsburgh, PA
    googling it helps. "mini me swap"
    most swaps tend to run the water pump that came with the bottom end. Unless your revving beyond 10,000 rpm i wouldn't worry.
    make sure to take out the oil control jet on the block as well.
    timing belt would be the one for the head z6
    D16Z6 Mini-Me Parts List
    check out some threads people post up to double check things and to get familiar with the swap.
  12. ibdalovely1
    dayton ohio
    :thankyousigna2: O wise Honda swapper :bow: for the info you have given it will be put to good use on another dead honda
