D15 and D16 interchangables
Cory lucas
So Have 2 motors that dont run for opposite reasons. i have a D15b7 that has a bad head. And the other motor is a D16y7 with a bad block spun a baring. I dont have cash to buy a new motor. Both have good trannys.
So my first question is can i put the D16 head on the D15 block and Frankenstein the two motors?
Second question is can i use the D16 tranny on the D15 block if the head swap works?
So my first question is can i put the D16 head on the D15 block and Frankenstein the two motors??
yes - Y7 head on the B7 block will raise the compression ratio to around 10:1
yes - you can use either transmisson
