once again OTHER than aftermarket pieces, are there any other motors that i can snag a camshaft from to bump up the power in my 1.5L civic SOHC non-VTEC?
if i were u id go to the junk yard, grab a SI head assembly (head, IMA, Dizzy, Injectors, the whole shabamm) and swap that onto ur dx block. it will bolt right up, then if u realy wana, get the si tranny. it has much betr gear ratio's u will realy feal a diffrence with this swap. nothin like 40 hp or ne thing but enough so u will tell. good luck
Tyler
