d15 distributor and rotor assembly on a d16z block
Discussion in 'HYBRID -> EG-EK / DC' started by 4DRonDUBS, Mar 31, 2004.
  1. 4DRonDUBS
    4DRonDUBS Senior Member
    can a d15b7 distributor and rotor assembly be put on a d16z6 block im in the middle of this head swap and i don't have a distributor for my d16z6 head.,...... I am also broke... help!!!!!!!
  2. BigJ
    I had a d15 obd 0 distributor on my d16z6 block. To get it on there correctly, we had to cut off the end of where the bolts mounted in on 2 sides, and we flipped it a whole 180 degeree to get it to work. It ran good, but was kind of off on timing. I recently bent a valve, so I had to rip apart the head, and its all disassembled, other wise I would just show you pictures.
  3. 4DRonDUBS
    If i cut the bolt holes will i still be able to put a stock d16z6 distributor. on when i get the money for one?
