d15 harness d16z motor
Discussion in 'ECU's, Electronics, and Tuning' started by evanjones, Dec 6, 2008.
  1. evanjones
    evanjones New Member
    I just swapped out the 1.5 in my 92 lx for the d16z6. i used the same engine harness. when i installed the p28 ecu i couldn't hear the fuel pump priming and the engine wouldn't start. i reinstalled the p06 and it starts. is the engine harness the same (minus vtec) or did i buy a bunk p28
  2. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    Check your thermostat ground, make sure you have it in the rite spot.
