i think my head gasket my be going out if its not already out ,is changing the head gasket somthing i could do myself if so what tools and stuff do i need
The single cam head gasket is the easiest to do. as long as you know how to set the timing after reinstalling the head you should have no problem. If you dont know, use a Chiltons or Haynes Manual. Pretty simple let me know any specific questions.
Super easy. I have done countless ones and its very easy, just make sure you set the gasket an make sure it seals properly by properly torqueing the head studs in the correct order, you can either look it up online or get a cheap manual. A good torgue wrench is a must.
