Cause I want the computer to work right until I can afford to change to a p28, right now still the stock p2p. Throwin knock sensor code and won't rev past 5k under a load.
you're kinda sol with this bud. before i decided to just get a p28 i did a lot of searching on how to add or bypass the knock sensor. i didn't find a single thing that worked. there was one idea that involved wiring up a piezo electric speaker to the fuel rail area and it would create a voltage that would trick the ecu into thinking it had a knock, but even that failed to work half the time. honestly it would be best just to save the energy and save a little more money and get yourself a p28. i bought mine for $100 but i've seen them for as low as $60.
