D15B 3 stage VTEC help
Discussion in 'Engine Building' started by Meshaq, Jan 23, 2010.
  1. Meshaq
    Meshaq New Member
    Hey, I am A Honda Motor swap virgin. Coming to find out not as easy as I thought it was. I got a JDM Motor. The swap is about as simple as it could be from what ive been told. Going from a D16Y7 non vtech to a D15B.... ince fit no motor mount rearranging or anything but I have a few question. What is a econmical VTECH my car doesnt have the vtech stamp on the heads so I had it checked out it has TWO VTECH cnyloids vs one. Any Ideas on that. Also the second Problem is the distrubitor. I need a VTECH one but i need to know what I can pull one off of. And how to wire an ECU for an Economical VTECH
    text me if you want to 928 848 7377 or email me back or here either or thanks.
    Michael
  2. tomzauto
    tomzauto New Member
    Lebanon, PA
    first off its VTEC - "economical" vtec means it has vtec but only on the intake valves, "power" vtec has it on intake and exhaust, as far as having 2 solonoids cant help ya there, there is only 1 vtec solonoid and on a d series engine its loacated in the corner of the head behind the distributor, you need a vtec distributor because you now have a vtec solonoid and the non vtec distributor mounts where there the solonoid is, just get a ecu from an obd1 d15b and your good
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Not really... there are quite a few different flavors of VTEC on the D series engines.
    VTEC-E was on the VX (5th gen) and HX (6th gen) Civics and only opened one intake valve at low rpms, effectively making the engine a 12 valve setup until higher revs allowed the second intake valve to open. The E stands for economy or something like that.
    VTEC in the SOHC D series engines is where you only change the characteristics of the intake valves.
    The three stage D15B (there are "normal" two stage D15Bs) combines the normal SOHC VTEC operation with VTEC-E operation, so there are two VTEC solenoids.
    Look in the top left corner- that's what the 3-stage D15B looks like with both solenoids on it.
  4. Meshaq
    Meshaq New Member
    The Photo is exactly what I have the two vtec slyoinds in left hand corner of the block! It does not have the Vtec stamp on the heads it matches the photo 100%. So what kind of a wiring harness is it. I was told it was aa obd2 not sure though. its going in to an 98 dx civic which is an obd2 right? And what USA block can I pull the disturbotor off of for that block? those are my two major question now I guess. Feel free to call me and help me make sense of all of this. 928 848 7377 verizon cell. Thanks for clearing that up for me. No ONE i mean NO ONE could identfy the vtec. So thanks guys a bunch!
  5. BrutalB83
    Rochester Hills, MI
    Next time, start your own thread please. You just butted in on somebody else's...
  6. phunky.buddha
  7. Meshaq
    Meshaq New Member
    still need to know the right distibutor for a d15b vtec. what honda block i would find in the states. someone said a d16z6 but any others?
  8. phunky.buddha
    Not sure exactly which one- but probably any SOHC D VTEC distributor with the same OBD revision would work.
  9. Meshaq
    Meshaq New Member
    Any idea on what that might be? its an 0bd2
  10. Meshaq
    Meshaq New Member
    and I would post a new thread but it wont let me yet no idea why but no good yet
  11. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
  12. Mr JDM
    Mr JDM New Member
    Buffalo, NY
    grab one from a d16y8 it will work
  13. Meshaq
    Meshaq New Member
    alrighty then thanks folks ill send pictures and update info as we go thanks again
    Michael
  14. Meshaq
    Meshaq New Member
    so I did some research on distributors and the y7 and y8 are indentical tue or false
