d15b block + d15z1 head high compression??
Discussion in 'Engine Building' started by xisco44, Sep 17, 2005.
  1. xisco44
    xisco44 Junior Member
    the d15b + vtec e head of d15z1 it suppose to goes compression crazy i have a friend with this combination he is eating stock sohc vtec like nothing i was thinking to put a d16y8 intake manifold and ls throttle body 58mm.
    the power band of the car right now is starting at 4800rpm all the way to 7200 rpm yeah its weird i didnt know that a vtec e head could flow that well :D
    do you think it would be a good setup becuase the d15z1 head stock come with a 40mm tb so it would be a 1.8mm increment i would like to hear your inputs thanks
