Civic_Tacoma
Member
I am curious if the JDM D15B will fit into a 1989 DX 4door. If it will what will I need for an ECU, and tranny? I have found a good deal on one and need some more info on it. Thanks.
Originally posted by toyz51@Oct 6 2003, 09:44 AM
One thing that might be tricky is the fact that the motor has two vtec solenoids, so you probably will need to just use a rpm activated switch to kick on the first one. If they made the motor before 96, you could find a jdm ecu for the motor and convert to obd1.
