SiR Master
The car will redline.
The d15b is essentially the "type r" of the d series
I thought the tranmission was in the car in your profile. Anyways, S20 would be the hydro transmissions(PL3 is the cable). There's no way to decipher what you have through the serial. Though, in this case, Si/EX is still 40mm and all others are 35mm.Actually I find none of those codes. Mine has a bar code sticker it reads S20 -1054638 and in fact S20 should be an Si tranny. I believe it has been played with and maybe repaired with the wrong parts?
