D15B (non-VTEC) to D15B (VTEC) Swap
Discussion in 'HYBRID -> EG-EK / DC' started by SRASC, Jul 18, 2008.
  1. SRASC
    SRASC New Member
    Planning on doing this swap sometime in the summer. Are there any parts from the non VTEC that can work in the VTEC?
    Also if anyone did this conversion in the past should there be anything I should look out for to avoid doing this and that, so that it'll be as painless an operation as it could be?
    Thanks.
  2. spiritofjosh
    spiritofjosh know your role!
    ocean gate nj
    im not positive on what can be changed from motor to motor but i know if you plan on using the non vtec wiring harness youre gonna need to get a p08 ecu (p28 works too) for vtec and you're gonna have to wire the vtec in yourself. unless you find a harness from a vtec motor then the swap is very basic
  3. Fitec Motorsports
    Fitec Motorsports New Member
    Ohio
    Whats the car? Are you meaning a head swap or engine? Is the stock motor multi-port? I’m installing a D15B vtec in a 96 civic right now for a customer and I have ran into a few problems because the engine is obd1 and the car is obd2. But if they are the same it should be a straightforward swap.
  4. 93jdmegtc
    93jdmegtc New Member
    you can used almost everything on the motor it is all the same excepts for the sparkplug wires and timing belt witch you will need a vx timing belt or a si timing belt all the mounts are the same
    and you will need a vtec wiring harness unless you want to hook vtec to a switch
  5. b16vt3c
    b16vt3c 95 EJ1 d16z6 turbo'd
    woodbridge
    all yu got to do is swap heads to a vt3c head bro
    good luck.................
  6. kchief89
    kchief89 New Member
    Coopersburg, PA
    sept the one I have is warped...
  7. JDMHondaDelSol
    JDMHondaDelSol New Member
    i have a 93 honda del sol with the stock d15 non vtec in it now but i wanna put a d16z6 head on to make a d15b vtec what will else will i need i know i need the p08 ecu anything else i should order?
  8. d-mon
    d-mon what r u compensating 4?
    p28 will work too and is more common.
    search b7/z6 mini-me.
    lots of detailed writeups out there
