D15b Swap Need Help
Discussion in 'Civic and del Sol - EG and EK' started by bistec, Jan 18, 2007.
  1. bistec
    bistec Project EH23
    :( :( :( Hi guys, i've finally got my d15b yesterday. I'm trying to change the timing belt ,the water pump and tensioner and now i'm facing a big problem. I can't get the crank pulley of. I really need help. I only have 3 days for that swap since it's my dd. How can i get this stupid :mad: :mad: :mad: bolt off? Thanks.:( :( :(
  2. welfare
    welfare Ancient Member
    New York
    Impact gun, easiest way I find.
    Make sure you use a good one, and try to make sure the engine doesn't turn while you are doing it.
  3. bistec
    bistec Project EH23
    I'm a little confused. Is a impact gun an air tool? I yes i will then need to buy an air compressor. What minimum hp should it be? How to get the motor not moving ? Thanks.
  4. welfare
    New York
    take it to a shop somewhere if you don't have air tools and a compressor, it'll cost you nothing or close to it for them to remove the bolt. If you live near albany, NY Ill do it at my place.
  5. bistec
    bistec Project EH23
    Thanks for the offer but unfortunately i leave in boston ma.:( . I took to a shop this afternoon. That thing is so heavy. My back is still killing me after i loaded it in a dx hatch. Not recommended at all. They asked me to come back tomorrow morning.
  6. joecivic
    joecivic save the single cams
    baltimore
    hand impact probably would haved worked if u dont have air
  7. bistec
    bistec Project EH23
    I've took it to a shop and it was amazing how easy it was for them to get it out with a impact gun (air tool). Thanks for all your help.
  8. 801CRX
    801CRX Got Rice?
    UTAH
    I learned my lesson after breaking 2 sockets with a breaker bar.
    air tools>hand tools
