d15b swapped into '99 civic
Discussion in 'Civic and del Sol - EG and EK' started by jameel11, Sep 15, 2009.
  1. jameel11
    jameel11 New Member
    Hi, I don't know if you guys can help me out here.. I swapped a d15b into a 1999 civic and used the p2j-003 computer..everything is hooked up.. but car not running properly..eg.it stalls..I was wondering if someone had a pinout of the p2j-003 computer so I could double check the wires..thanks
  2. CmR333
    CmR333 CANT THINK OF ANYTHING
    JACKSONVILLE FL
    D15B is an obd 1 engine and dizzy, if you running an ob2 ecu and injectors there lies your problem.
  3. RoughKnight
    RoughKnight Christmas Car
    Ottawa, Ont
    ^^ gotta be more specific so we can help you out better. There are two versions of the d15b, and how does it stall? when u push the gas? does it studder on idle? without gas? cel light on?
