d15b vtec and d15b7 coolant outlet size??
Discussion in 'HYBRID -> EG-EK / DC' started by 93civicracer, Feb 24, 2008.
  1. 93civicracer
    93civicracer Oh, I do a little here and there.
    Texas
    Well I've been having problems with the coolant leaking I keep fixing it and it's good for one day, then the next day I go to work and come back to a tiny puddle really tiny puddle of coolant, and it keeps leaking from the hose outlet on the engine that fits the lower radiator hose. No matter how I clamp it on there, how tight I clamp it, it either pinches and leaks or it seems to be on right then starts leaking later on! I did a pressure test because I thought there had to be a crack or something and fixed another leak there was a hole in the heater hose but now this one on the lower radiator hose is getting on my nerves. Advice? Outlets different on d15b vtec and b7? I've tried everything I can think of is there something else I can do? The hose itself is fine no cracks or holes. Any comments are much appreciated!
  2. H22juggsEG
    H22juggsEG New Member
    got tape measure?
  3. 93civicracer
    Texas
    yea well the other engine is at a friend's house almost 10 miles away it was the only place I could find to store it so I just haven't got around to checking it yet
  4. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    I thought they were the same sizes. I'm using stock CRX hoses on my D15B VTEC. Maybe bad hose or leaking from the housing itself?
