K2e2vin
My car had to go to the shop to get the rear subframe fixed, so when I put the D15B VTEC in, I didn't put in the engine mount(only the three mounts on the transmission). I'm using a jack to support the engine
I finally took off the engine mount off of my D15B2 thinking it'll just bolt up to the bracket on the D15B-VTEC, and found a problem. When I line up the bolt holes with the stud; it won't really fit and it's also crooked(as in not even come close to slipping into the mount location in the engine bay). Should I just slot one of the holes on the mount or do I need to use another mount?
Thanks, Kevin
Thanks, Kevin
