Thanks. Couldn't get much done today but I did get started on the shift linkage (got the extension rod off) and started on hubs. Got the damper forks off and I'm going to disconnect the lower control arms from the steering knuckle and let that hang so I can pull out the axels.
On the shift linkage...I got the extension rod off easily but the other one...
The "bitch pin" or spring/wrist pin whatever wasn't even there! I slid back the boot, the clip was missing, and there's a little 8mm hole there that I shoved a small screwdriver all the way through. I guess the pin isn't necessary since I've driven the car like that a few times before the b7 pooped. It's even clogged with grease n shit it looks like it's been that way for a long time. Is this serious?
Tomorrow I'll have enough time to finish my swap I think so as soon as I get the shift linkage all the way undone I'll get those axels out and swap motors before any damage to hanging steering knuckle can be done.
ALSO to take the lower control arm disconnect from steering knuckle it's the nut on the bottom below the brake right? It looks like there's some kind of spring underneith or something and as hard as I've tried, I can NOT get that nut loose. Any advice?
Thanks
