impulse94ex
Member
ok i will probly get all kinds of laughs, but i found a cheap d15b vtec with low miles, i was wondering what the hp and tq gaines would be with a d16z6 head or if it would be a waste to do the head swap??
yeah umm i am real short on funds and have a d16 with a hole in the block, but a good head and the d15 is cheap and easy to get a hold of, and to drop right in....if i could find another d16z6 for under like $800 i could do that. also it is the 130hp d15bQuoted post[/post]]
Depends on which D15B vtec it is. But, I'd say that even in the best scenerio you'd be wasting time and money.
thats what i figured i just wanted to know if there was a difference in like the intake manifold or cam or anything that would make a difference.Quoted post[/post]]
The 130hp D15b head is almost identical to the Z6...why would you want to swap the head?
Quoted post[/post]]
You should be able to find a D16Z6 longblock for well under $500, I've seen them, for $100 or less. If the hole in the block is the only problem than you can reuse the tranny, axles, IM...everything.Quoted post[/post]]
i wanted to find something with low miles and the jdm b15 only has like 35000mi on it sooo...Quoted post[/post]]
thats one im talking bout...Quoted post[/post]]
You can get a D15B shipped from Hmotors for $600. I got one about a week ago.
awsome man, thanksQuoted post[/post]]
The D15B VTEC="D15Z1 bottom end w/ D16Z6 head". A P28 works fine, a P08 will work better. If you're going to tune it, It doesn't matter.
Quoted post[/post]]
Quoted post[/post]]
Quoted post[/post]]
Quoted post[/post]]
the cam in the bvtec is slightly better than the z6 cam
Quoted post[/post]]
partially right but the z1 with the z6 head would be way too high in compression. the bvtec has its own special pistons...
