d15b2 and d15b6 head question
Discussion in 'HYBRID -> ED-EF / DA' started by hatchstatus62, Apr 27, 2009.
  1. hatchstatus62
    hatchstatus62 New Member
    san diego
    Hey people hows it going. I'm new to hondaswap and new to hondas pretty much, only been into it about 2 months now. Well i bought a 1990 hatchback dx about 2 months ago and it came with the d15b2 obviously, well i bought it to be a project car, but it's also my dd from san diego to rancho every day for school!! but anyways i had really low comp. in 1 cylinder and it was burning oil (rings) so i really didn't want to keep driving it like that so i found a d15b6 out of a 91 crx with the tranny and computer and all that good stuff and i just finished that swap 2 days ago, well i know the b6 has only 8 valves and my b2 has 16 valves and i was wondering if i could put my b2 head on the b6 block like will all the coolant ports and everything match up along with the head gasket. I'm wondering cuz i put a lower horspower engine in a heavier car (stupid i know) but i picked this engine up for 300 and it runs really good, just lost a lot of power, running pretty rich, and my exhaust isn't as loud as it used to be. I appreciate any help, thanks. also i'm running the b2 computer and distributor, should i be running the b6 comp and distributor.
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Everything would line up but the pistons probably will not work. The HF pistons have 2 valve reliefs and the DX have 4.
    If you want to improve the DX engine for cheap; rebuild it(fix the rings), do MPFI conversion, swap in D16A6 cam and ECU with 96-00 D-series cam gear, 99-00 D16Y8 header. If you want to go a little further, you can drop in PG6B or P29/PM7 pistons along with milling the head a little bit to bring up compression but you'd want a tune also.
    Of course, do all of that while the HF engine is in the car. That way you'll minimize down-time.
  3. hatchstatus62
    san diego
    Thanks ya that sounds pretty good so with those mods ill have a ptetty decent d15. I got a quote from an engine remanufacturing place near me that will rebuild the entire engine including bearings machining and honing basically a brand new engine for $1300. And I can just have them do those pistons and the head. Should I get the head ported and polished.
  4. K2e2vin
    Raleigh, NC
    You can since you will have the head off anyways; but that's entirely up to you. IMO, you won't see much gains with a ported head unless you have a aftermarket cam and intake manifold to compliment it.
    For $1300, you can get a used JDM motor. They're usually around 40,000miles and cost much less(usually around $500-$600 for a longblock). If you're set on rebuilding it; might as well have them swap in the pistons though since that's more time consuming than taking off the head. Also, I'm assuming that $1300 includes new oil pump, water pump, and timing belt/tensioner?
  5. civicracer04
    civicracer04 New Member
    Does anyone make a cam for the d15b2?
  6. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    WOW....any cam that fits in th D15b7 or D16a6 will work. If the A6 cam is chosen youll need a Y7/8 cam gear to correct the cam timing back to zero. There are many aftermarket cams out there, try google.
  7. K2e2vin
    Raleigh, NC
  8. wifeCRVmeEF
    wifeCRVmeEF New Member
    With $1300 you can most likely have a JDM D15B VTEC swapped in there. Parts i hear are kind of hard to find on these, but man are they great motors i here. Try a search on these.
