d15b2 build!? any sgle cam guys helps would be awesome
Discussion in 'Engine Building' started by dreescrx, Sep 7, 2009.
  1. dreescrx
    dreescrx New Member
    <p>i have a d15b2 i want to drop in my 1990crxhf rightnow it has the stock d15 i was wondering if that tran will work with the nw motor i was told same block so should work? also what would be best set up for Turbo kit? any help would be amazing!</p>
  2. Bobby17772
    Bobby17772 New Member
    Enfield, CT
    as long as it's a D series engine, I believe that the D15b2 will bolt right up. convert it to mpfi, get 450cc DSM blue top injectors a 255 fuel pump, cast turbo exhaust manifold, and for a turbo I would say probably a 15g or a t25/14b from an eclipse/talon.
  3. dreescrx
    dreescrx New Member
    <p>
    </p>
    <p>&nbsp;</p>
    Anychnce would you know what EcU would be needed?
  4. GlassHeadlights
    Calgary, AB
    If MPFI use a chipped PM6. Or better yet convert to OBD1 and use a chipped P06.
  5. Bobby17772
    Enfield, CT
    if he converts it to obd1 couldn't he just use a p28? I'm probably wrong but just throwing it out there
  6. efhondakid
    Akron-Canton, Ohio
    Yeah because a non vtec motor would benifit a ton from a vtec ecu.
  7. dreescrx
    dreescrx New Member
    So what would be the best set up for turbo and accel
