first off is it worth even trying? im planing on turboing my z6 in my cx. i have a z6 in it now with my cx tranny. its slow off the line but it takes off at 3600. i beat a 92 si with it. n e ways if i put a cx crank in it ,it will lower the comp.and at the same time have better revs. i will have absolutly no torque but once boost kicks in it should be pretty crazy. is it even possible to put in tho?and im also about to rebuild all of it over the summer. im balancing and p+p. ne little tips that i should be doing while the rebuild?should i do n e nitrating,meleniting,or cryogenics. n e info helps. if its a stupid idea with that creak tho let me no
