D15b2 - d15b7 - b18a1
the starter worked fine before i pulled the engine to put a new tranny in. could it be unplugged or bad wires? or all together the starter?
it could be the starter solenoid. but if I were you, I would just try to get a new engine harness if it's all hacked like you said
ok, its turning over. had a bad battery and clutch cable wasnt hooked up. pushed clutch in and put new battery in and it turned over. now im chargin/g this battery to get the car running. i have another harness but i think it is dpfi. i have everything i need i think. can i use a dpfi harness and wire it to mpfi?
