D15B2 + D16Z6 head. low budget build??? CHIME IN PLEASE!!!
Discussion in 'HYBRID -> EG-EK / DC' started by RadekSkylark, Nov 8, 2009.
  1. RadekSkylark
    RadekSkylark New Member
    Ok, I got EG 4door, for DD, and it will stay as DD [​IMG] so, I can get z6 head, rebuilded for ~350$, then was thinking of some 4-2-1 header, got an 60mm exhaust, then get in tuned [​IMG] in Compression Calculator by ZealAutowerks i did this setup with d15b2 stock block + unmiled stock z6 head, 2layer HG, and got CR 10.54:1, so whit this setup runing on 93 gas, and a good tune, what could be the nummbers on wheels - hp/tq??? And if I will do this, the next step will be z6 block 75.5mm PG6 pistons, lightened flywheel, and oem z6 HG. it will get me to CR 11.8:1 on the same 93 gas. Or, I will do something with head internals, the best i was thinking of is bisimoto stage 3 camshaft + AEM cam gear, valve springs & retainers... and so on.... BUT, the question is, whit the start Mini-Me setup CR 10.5:1, 93gas, rebuilded z6 head, 4-2-1 and 60mm exhaust + good tune, what could be nummbers to wheels??? ok guys, thanks alot [​IMG]
  2. josh_crewdson@y
    josh_crewdson@y New Member
    nova
    you'd have to get it tuned. when they tune it they'll give you numbers.. my guess would be around 130hp with a good tune...
  3. josh_crewdson@y
    nova
    by the way, the eg came with a d15b7 and the ef came with a d15b2.. what year car is this going in? 88-91?
  4. RadekSkylark
    Its going into EG8 Europe Domestic Market... it came with d15b2 engine.... eg 4door
  5. RadekSkylark
    130whp or at the crank???
  6. josh_crewdson@y
    nova
