D15B2 Modifications
Is the D15B2 Engine from Europe the same
  • Total voters
    3
ukcivicguy
What Can I do?
Hey there, im new to this forum so hi to everyone out there.
Im from the UK and from looking at various forums I realise that the engine in my car is the same as the 88-91 engine from the states, its the DPFI 1.5 Block, know as the D15B2, I want to convert it to MPFI but will it be the same swap, as I was going to take the complete inlet manifold off a 1.5 Civic Coupe (MPFI) Which is built in the states with Engine code, D15B7.
Well there you go, all help will be appreicated! :spin:
Thanks
It should be the same... and engine code is an engine code, regardless of what country it originated in. All D15B2 engines should be the same. In any case, if it's a DPFI D block, you should be able to convert it to MPFI the same as any other DPFI to MPFI conversion.
