D15B2 Rebuild
Discussion in 'HYBRID -> ED-EF / DA' started by hondahauge, Aug 25, 2003.
  1. hondahauge
    hondahauge Senior Member
    Would the ZC pistons and head work on the D15 block?
    If not which other pistons and rods ,head work on the D15 block? Should I get the Titanium Valves for it?
    Justin
  2. smashed4thgen
    smashed4thgen Senior Member
    here is what i was going to do
    a1 pistons (1st gen integra)
    y7 head (96 and up dx i belive)
    and delta regrind cams
  3. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    no stop dont pass go
    the b2 has no pot. it is dual point injct.
    go to the junk yard get a d16a1 for 50 through it in the car and go from there. it is a good turbo motor and zc parts and cams can easily be found for it
  4. smashed4thgen
    actualy the d15 has a lot of potential... with a mpfi swap of course...i didnt mention that because iam sure anyone that knows hondas knows that the dpfi of the d15's sucks and that to make any power its a good idea to change it
    .... B)
  5. smashed4thgen
    also the only single over head cam for the zc was vtec...and the dual cams wont work with the a6 head...and the dual over head cam head dont fit on the single cam block...and if u use a single cam zc head on the a6 block (mini me)..that would suck compared to super high compression and a 270 grind cam...
  6. hcivic.com
    ya the d16a1 is a dohc motor
    the 88-89 tegra
  7. smashed4thgen
    wich dosnt bolt in to that ef chassi and if u were goin to do that much work thats when a b swap should take place..(and my bad on thinking u said a6
