d15b2 stock turbo?
accord218
hello i was wondering if it would be posible to turbo a d15b2 motor with stock everything. im also wondering if posible what would have to be done and what would be needed for it and how much everything would cost.
thanks
hi, build my turbo kit for me
homemadeturbo.com
no, you can not leave everything stock...
you will need a turbo manifold, turbo, down pipe, intercooler tubing, intercooler, oil feed and return, and at a bare minimum a high flow high pressure fuel pump with an fmu...
you can however leave the motor completely stock...
uhm... isn't a d15b2 DPFI? if so good fuckin luck... i would advise ou convert to MPFI before attempting any forced induction setup...
