D15B2 to B16A Wiring - Which Wires?
geoff-r
Hi there I have a 92 UK Civic LSi, with a 1.5 DPFI D15B2, I've recently dropped in a B16A from a JDM del Sol SiR, everything is hooked up fine on the engine side but I've come to the wiring now. Trying to cut down on costs I have both the del sol dash loom and the civic loom. From what I understand the civic will have vtec pre-wired in on the cabin side of the loom, just not to the ECU as the ECU is a P04 non-vtec ECU. I have the P30 ECU from the del sol and I'm planning to take the plugs that go to the ECU off the del sol loom and re-pin the civic loom to that using the P30 ECU with the B16A. Does anyone know exactly which wires will need to be run in addition to the re-pinned ones? Such as the extra shock tower block...
