d15b7 dizzy on a d16y5
Discussion in 'Engine Building' started by JoeDaddy, Sep 23, 2010.
  1. JoeDaddy
    JoeDaddy New Member
    Dallas, TX
    hey guys i was wondering if a d15b7 dizzy will work on a d16y5 . ok here's what i got, i recently bought a 95 2dr civic ex with a d16y5 swap, the original motor was a d16z6 well the z6 is a 0bd1 and the y5 is a obd2 i was told to use the dizzy from the d16z6 but it seems like the car runs sluggish and besides only one bolt lined up on the dizzy to head. on a previous thread that i posted i was also told that a z1 dizzy would work and bolt up fine but a friend just happened to have a d15b7 dizzy laying around he's shop and said it would also work just fine it's also a 0bd1 . does anyone know if this is true? and if so do i have to do anything else other than just plug it up? i just started getting into tuners and i dont know much so your help is greatly appreciated , thanks in advance for your inputs.
    1 person likes this.
  2. boostedls
    boostedls hmmm.. i like pie
    Elkhart
    the d15z1 dizzy should work.. does it rev over 4.5-5k?
  3. boostedls
    Elkhart
  4. JoeDaddy
    JoeDaddy New Member
    Dallas, TX
    hey boosted thanks for responding, well i put the d15b7 dizzy on yesterday and drove the car around and it seem to be running fine but felt a little sluggish and yes it does rev up well over 4500. im using the d16z6 ecu that came in the car originally since it's a 0bd1 ecu and the d15b7 dizzy is also a 0bd1 but it came out of a non vtec del sol. will that matter?
  5. boostedls
    Elkhart
    i'm not sure if it would matter but as long as it drive and get you to a to b who cares right lol
  6. JoeDaddy
    JoeDaddy New Member
    Dallas, TX
    thanks for all your help boosted, i have two more questions. first is how can i check to see if the timing is right and what should the timing be set at. second is after driving the car a few miles it ran hot the fan never came on, any ideas. when i bought the car it was wrecked in the front i had to replace the radiator and fan, i went with a racing radiator and a flex a lite fan ( thinking of boosting it in about 2 months ) i checked the connections and they were good, i removed the sensor below the dizzy and ran a test with a multimeter and a mini torch and it sent a signal when it got hot enough only thing left to check is the thermostat i think. the reason i asked about the timing is that i changed all the pulley's to obx and the crank pulley has no marks on it, ii also changed the cam gear to a vms adjustable cam gear. im just trying to make sure the timing is set right. sorry about the long thread,
  7. JoeDaddy
    JoeDaddy New Member
    Dallas, TX
    anybody have any inputs? i need all th help i can get, dont know crap about tuners. im a motorcycle drag racer and thats the only thing that i know how to work on. please feel free to leave your input they will be greatly appreciated, thanks in advance
