D15b7 going into 93 si......need help asap
Discussion in 'HYBRID -> EG-EK / DC' started by turbohatch900, Mar 7, 2010.
  1. turbohatch900
    turbohatch900 New Member
    I had a 93 hatch si and it came with an ls motor and tranny setup but i wanna put a D15B7 while my type r is being built..... the problem is that im wondering since the ls had a custom engine harness will the d15 harness fit to the car without customization and will my jdm cluster read the motor or would i have to replace my cluster with the stock one again....please let me kno i need help fast!!!!!!
  2. d-mon
    d-mon what r u compensating 4?
    a d15b7 engine harness should plug right in to any 92-95 civic.
  3. SLP10
    SLP10 New Member
    Well first off a B18 LS Transmission is bolted to a D15B7? Really? I dont even know how that is possible because they are different series motors. Get a stock D series Transmission and a stock Non Vtec Engine Harness and you'll be good to go.
  4. Makahana187
    Makahana187 New Member
    as long as the connectors in the engine bay weren't modified the d15s engine harness will plug and play and the jdm cluster should read the engine fine, unless the connectors in the bay were messed with but i see no reason to do that so you should be all good
