d15b7 in 91 crx hf
Discussion in 'HYBRID -> ED-EF / DA' started by jgrimey, Apr 16, 2013.
  1. jgrimey
    jgrimey New Member
    i only got 1 ? guy i bought the car from swapped in a d15b7 and it throws only one code which is code 1. i figured i buy a 91 crx hf o2 sensor still cant stop the code from flashing i ran a new wire just for the 02 sensor still same problem, any help would be very helpful as im new to honda and this is my first honda buy.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    what computer is on the car
  3. jgrimey
    jgrimey New Member
    Pm6. I've tried the pm8 the stock hf and I throw like 5 codes. I've even used a pr4 after awhile the car cut off
  4. AHHVTEC
    Alabama
    has it been converted to obd1
  5. jgrimey
    jgrimey New Member
  6. AHHVTEC
    Alabama
    you need to do that. or convert the new motor back to obdo
  7. jgrimey
    jgrimey New Member
    im using the stock 91 hf dizzy if i can get pics i will. its using obd0 injectors. does the placement of the o2 sensor have to do anything with it? im just throwin ideas out there lol
  8. AHHVTEC
    Alabama
    as long as its in the stock manifold/header it should be ok.
  9. jgrimey
    jgrimey New Member
    i bought car like this maybe its usin the 92 civic lx header? any way of tellin if it is?
  10. AHHVTEC
    Alabama
    im sure there is but idk right off hand, as long as the o2 is in the stock bung location it should be fine.
  11. jgrimey
    jgrimey New Member
    thanks for your help i had to buy a exhaust manifold and exhaust system. found out that my o2 was supposed to be further down on the manifold almost where the collector is. once again thanks for ur help.
