93civicracer
Oh, I do a little here and there.
So I'm getting rid of left-overs and D15B7 engine parts. For new guys to know, all D-series engine parts are pretty much interchangeable, if you have a question just ask.
EVERYTHING is best offer need most of this stuff gone
-ECU original d15b7 ecu USDM
-Valve Cover - says 16 valve, spark plug holes to the rear closer to driver
-Head - supposedly bent valve, I'll be taking it apart to see what's wrong if you want, has everything
-Block - with pistons, crankshaft, rods, everything included or will sell separately
-DX Transmission
-flywheel
-clutch
-starter
-alternator
-powersteering (bracket, unit, lines, ask and I will check to be sure)
-spark plugs and wires (new)
-distributor
-exhaust manifold from d15b vtec swap two piece 4-2-1 design, I used the b7 exhaust for the swap
-oil filter
-intake manifold (don't remember if I used the b7 or the d15b vtec manifold, I can check if you need)
Need it GONE make offers!
-DX Transmission
-flywheel
-clutch
-starter
-alternator
-distributor
-oil filter
