d15b7 swappable parts list????
Discussion in 'Civic and del Sol - EG and EK' started by 97superteg, Oct 19, 2008.
Highest HP not ease of execution or most common
  1. d15b7 Frankenstien (NA)
    0 vote(s)
    0.0%
  2. d15b7 mini me swap (NA)
    66.7%
  3. d15b7 FI
    33.3%
  4. d15b7 Frank FI
    0 vote(s)
    0.0%
  1. 97superteg
    97superteg New Member
    hey all. couldnt find this info anywhere on the net, and im a automotive student. i have a d15b7 motor from a 94 civic lx. im pulling the motor out, well actually its allmost done. im going to do a full rebuild on it since it needed new valves. i want to do with it the same thing im doing to my 97 GSR b18c1. put new oem type r pistons, rings, with oem type r intake cam, and type r valves or maybe just bigger valve springs and retainers and machine the old valves. i want to do the same thing to my civic motor to get more out of it. is there a list of compiled parts from different motors that will fit in the d15b7 motor? i know with B series allmost anything is interchangeable to some extent, and i know it is the same with the D but only i cant find anything for it. or is there no way to do it without doing mini me or somthing to that extent. like i said im doing the same thing with my b18c and swapping it with b18c5 internals and getting like +25hp. i just want to know if this can be done the same way but with the d15b7.
  2. BrutalB83
    Rochester Hills, MI
    I would just do the Mini Me. It's not like D-series stuff is expensive...
  3. 97superteg
    my point is, i want as much power as possible WITHOUT vtec. i allready have a vtec so i want to mess around with the non vtec setup and get credit for it in school.
  4. frodotoolbox
    frodotoolbox 92 civic si d15b
    sc
    i beleive the s model del sol is a non vtec d15 you could just pull one of those from a junk yard if you want
  5. BrutalB83
    Rochester Hills, MI
    If that's the case then a junkyard turbo kit is going to be the best bang for your buck. There aren't really many OEM parts you can stick into that motor that will make a big difference power-wise...
  6. efhondakid
    Akron-Canton, Ohio
    :werd: I would throw some boost into it, tune it and call it a day.
